15-34
35-54
55-62
It worked, thank you!
Thanks for your help. I have a question... How do i change the radius in the view port?
Hi Ron, sorry in v4 there isn't currently any way to change the radius value for that particular part of the UI.
I got really busy over the last couple of months and haven't checked in.
Thank you, Michael, for helping OGAR fix the issue. It looks like he installed the "Dark Gray Theme (MoI 4.0 beta) v1.1.1.zip" file and then the "Dark Gray Theme (MoI 4.0 beta) - Custom UI Bar.zip" file. The second one is only to put the Custom UI buttons in a separate row at the bottom of the screen. A user does not need the second ZIP file to make use of the Custom UI at all, as you probably know. It's purely optional if people have a lot of Custom UI buttons.
I'm glad you like the theme, OGAR. Sorry that my instructions are confusing. I'm going to revamp the first post one of these days and make it crystal clear as to what does what. I'm actually too busy using MoI to do it right now though. ;-)
I never realized before how powerful the Deform command is for jewellery design. This software is a godsend, Michael!
-- Cody
i've just installed it.
it's beautiful!
tnx for taking the time to create this for us Cody!! : ))
perhaps in future release this could be a check box in the install options....to just click and pick themes.
Hi Neil, yup I definitely want to have a dark and light theme built in to MoI in the future, it's just something that I haven't been able to put any time on as of yet.
Hi Cody,
any chance that you update your great dark UI to the latest beta version?
Cheers,
Axel
Hi all!
I love this UI, but I'm having a bit of a problem. Everything works great when I install this theme, as you can see.
But when I install the Custom UI Bar, things change.
It looks like the viewing panes are resized, which compacts the browser, making the text unreadable. Or maybe it's the other way around and the browser shrinks, making the panes larger. (???) There is no way to manually grab the browser edge and resize it.
I think this UI is fantastic and would like to keep using it. I would like to keep the double row of buttons so I don't have to scroll left and right. But it's vital to be able to read the information in the browser.
Is there a way to fix this? I know very little about code, but I can poke around and change a line of text if someone guides me. I just have no idea where to begin.
-Patrick
Hi Patrick, yes the problem is the UI is a snapshot of some older files, and it's missing an attribute for setting the browser pane to be resizable.
The file that you need to edit is MainWindowLayout.xml which is in the ui subfolder.
Line #6, the one that defines the browser pane needs to be like this:
<UIPanel dock="right" resizable="true" defaultWidth="15em" src="moi://ui/BrowserPane.htm"/>
You'll be missing this part: resizable="true" defaultWidth="15em"
once you add those in then your browser pane should resize again.
Awesome! Thank you, Michael!
is that for the latest MOI version as well and originally the one from Cody?
Cheers,
Axel
Yep that works fine for the V 4 beta ;)
Sorry for the late test : i have put the minimum! Because I had a previous little Tools Bar sufficient for me... ;)
In French of course for me! ;)
https://moiscript.weebly.com/trucs-astuces.html
and so...
Hi All,
Is there a version of Cody's dark UI that works with the final release of v4?
If not, what are the main differences if I wanted to burn the time to rebuild and make it work?
Thanks for the help!
+1 for a pinned thread on theming that gets updated
+1 for an 'official' dark theme for Moi
Hi Lavellotron,
You'd do a diff between the default v3 moi.css and the modified version, and then apply the same changes onto the moi v4 moi.css file.
You can't just copy the entire v3 UI onto v4 because then you'll be missing the changes in moi v4.
Good tip, Michael. Thank you.
I'm on macOS. Oddly, when I replace or update icons and the moi.css, nothing appears to change.
I'm modifying the files located here:
/Applications/MoI\ v4.app/Contents/Resources/ui
Is this the correct location?
Hi Lavellotron,
Yes, that is the correct location, the main file to edit is moi.css located there, there are a couple of dark versions of moi.css here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=10199.3
The PNG image files for most of the buttons are in an "icons" subdirectory underneath ui.
Did you have MoI open while you were making changes? They won't show up until you close MoI and relaunch it.
Thanks, Michael.
No, what happened was the magic of dock shortcuts linking to the app in Downloads and not the one I dragged into Application. Doh!
Thanks, happy camper now.
Hello,
I am new here!! Hello everyone!
Is this Dark Gray Theme here available for the final version?
Thanks!
E.
15-34
35-54
55-62
