Full Version: Segmented Edges | Fillet Error
19 Jan 2019   [#1]
Hello everyone,
One of my edge appears to have multiple segments, which prevents the Fillet command to compile properly.
When I "Join" the segments, it creates a new, separate (detached) curve as oppose to fuse the segments from the original geometry.
The newly created curve was translated upward in image MOI_03.jpg to show it is separate.
Anyone aware of a command that will weld the segments together?
Thank you!
-J
19 Jan 2019   [#2] In reply to [#1]
Hi J, there is a Merge command that can glue together segmented edges into longer single edges if they are smooth to each other. Some info here:
http://moi3d.com/3.0/docs/moi_command_reference10.htm#merge
19 Jan 2019   [#3]
That's exactly it. Thank you so much Mike!
-J
20 Jan 2019   [#4]
Thank you for asking and answering this as i too wondered about this, subscribing to the Forum RSS is paying dividends in my moi learning.
