Show messages: All
1
2-3
Hi Sven, objects that are not touching are always considered separate objects in MoI, but all of them can have the same object name or style assignment.
When you export to a rendering program like Blender, objects that are assigned the same name will export to a single mesh, unless you have disabled the option under Options > Import/Export > "Combine same named objects".
Style assignments in MoI become material assignments when exporting to .obj format, so if they are all assigned to the same style they should be all assigned to the same material in Blender.
So depending on what you want you could assign either an object name or a style to those objects you want to behave as one.
that's good news!
Thanks again,
Sven
Show messages: All
1
2-3
