Hi all,
while steganography is not new and is often used to hide stuff inside
images or videos, i thought why not give a 3D model file a try.
So i took an old little .3dm file of mine and embedded an .mp3 file
which i created with macOS's say command and then run through
the lame encoder.
Maybe some of you find this interesting for inserting a hidden
copyright notice etc. in your files.
Please note: I did not extensive tests, so in case of any (file) damages
i am not responsible! It is more or less a test for me, if this could be
done.
Here is a picture of the model:
Here is the link to the .3dm file (expires in 30 days):
https://ufile.io/7gkeb
and here is the link to the software i have used. In the binaries
folder you can find compiled versions for most platforms.
https://keybase.pub/stefan_claas/software/steg/
Hi Stefan,
Cool idea for a digital "watermark".
1 - Where do you find the mp3 file inside the 3dm file?
2 - I'm curious how you modeled a knife edge into the 3 blending ovals? Tried to reproduce that and I get close but with a slight bubble on the Y-axis center seam surface. Tried sweeps, blend and network using the curves in your 3dm file.
Thx.
M
Hi mat10x,
thanks! you will find the hidden .mp3 file when you download
the steg program from my download link and then run the
command (in a Terminal or cmd.exe):
steg show -input hidden.3dm -outputdir path/to/dir
Regarding the modeling i did that many years ago,
so i can't help that much, because i forgot the steps.
Only thing i remember is that i used also ViaCAD
for this model to get the proper N-Sided Surface
at the tail.
