i have a question for you, regarding EEVEE. O.k. you cover interior
shots but do you know also if EEVEE works with a shadow catcher
for outside shots, lit with HDRI's?
And does EEVEE support Multiple Importance Sampling to cast
shadows from (high quality) HDRI's?
I ask, because i played with MIS in the past with Cycles and it
gave great results, but i had to fiddle around a bit to set this up.
This was one test i did long time ago and the shadow quality
looks imho really good.
EEVEE can use an HDRI to provide ambient lighting for a scene, as well as create the backdrop image for a scene. Unfortunately, at this time, EEVEE does not support using HDRIs to calculate shadows.
In my course, I show a world node setup where you can use an HDRI as a background image, but use a different color for the world ambient lighting. You can also do the reverse, use an HDRI for a ambient light and a solid (or ramped) color for the backdrop.
indeed this thread is very interesting, because it shows (me) also that no post-processing
was involved, which i usually do a bit, after rendering. And the images there look quite
superb imho, comparable in quality to all those commercially available unbiased render
engines.
Well, i hope that my PC will arrive by end of this week ... ;-)
i just want to let you know that i have purchased your course an hour ago and looked already some chapters.
You explain it very well in detail and based upon your tutorials i will then later try if i can set-up proper product
shots for my doodles. :-)
Prior downloading your course i tested with the "Tree Creature" scene, from blender.org, my little graphics
card and the scene was rendered in 2.63 seconds as image file, which is very very good for me.
Should i have questions coming up, with your course, i will post them here.
And because MoI3D has the best NURBS to mesh exporter I've ever seen, you files can come directly into Blender and are ready for rendering! If you're looking for more info on how to set up Blender for rendering (not modeling) you can check out my other product: Definitely EEVEE: Definitive Interiors. In it there's a newbie step-by-step on how to download and set up Blender, configure it, and set it up for still and animations. You can use either the Cycles unbiased renderer (like KeyShot if you have a GPU, a bit slower on CPU) and of course the realtime lightning fast EEVEE renderer. It's at https:/gum.co/EEVEE
I really think MoI3D + Blender 2.8 is a perfect workflow for creating stunning renders.
Looks cool. I'm a Maya user since Maya 4.0 and MAX since dos so I've been hesitant about blender but AD is doing the same as Adobe. However I like your tutorials so maybe time to add blender to toolset. I'll also throw out (not Free) but I can't recommend Redshift3D enough. I've migrated it to our work and home use. It has replaced our render farm all GPU but its fantastic at least for Maya and MAX C4D etc.
Yeah, Redshift is pretty cool, and I hear it works with Blender. I bought Octane twice, and both times received refunds because the SketchUp plugin didn't work at all. The Cycles render is actually pretty good.
As often goes, people coming from one software to another most always have a difficult time adjusting. Blender 2.79 was particularly tough. I took copious notes using Google Keep so I could quickly reference them later.
Then came 2.8 and Blender finally decided to bring on board some real UI folks. The difference is amazing.
I've never been much a fan of Open Source, but I have to say Blender has yet to disappoint. My guess is you'll miss some features from Maya and 3DMax, but you'll have others. The non-destructive modeling workflow is just amazing.
Check out KIT-OPS.com for some really interesting kitbashing ideas.
