Show messages: All
1
2-4
Hi Tom, the main way to improve that is to make your object a solid rather than an open surface. You can do that by using the Construct > Planar command on your base shape before you did the fillet, that will put top and bottom end caps on it. With the end caps in place if you then fillet those edges the fillets will be extended past and trimmed by those end caps and give a result like this:
Hope that helps!
TomFillet2.3dm
Hello,
After an experiment it looks like the issue is the input surfaces. Once those are straightened out your fillets shouldn't exhibit those distortions.
Thank you both for your help !!
Show messages: All
1
2-4
