Show messages: All
1-2
3-5
Thank you Michael !
DonĀ“t bother with it takes to much of your time, I had thougt it would be
just a short aditional line in the html file.
Just working on a series of endless objects with the same angle / length -
extrude parameters so it would be a little tiem saver to have a default
option ...
Hi Tom, one thing that could help is to use this to automate pushing the tapered button and draft angle:
extrude tapered draftangle=20
Then you would only need to type in the distance.
Also don't need to do these one by one you can select a large number of closed curves and do them all in one go of the Extrude command.
Very cool - thanks !
Show messages: All
1-2
3-5
