Show messages: All
1-6
7-12
thank you. If there was a spectrum with say Houdini and ZBrush on the left then MoI would be on the far right side ;) The UI paradigm makes it ridiculously fast to work in. I have defined shortcuts for everything and couldn't be happier. Well, I would love to have a fullscreen "pro" mode without any toolbar. Don't know how difficult that would be to implement. One thing I noticed it that fillets and/or chamfers often fail on relatively simple geometry if the model is too small in scale. When I scale it up it works again. I would have expected these function to be independent of model scale.
Best,
Sven
Hi Sven, it is possible to hide the toolbars, try the plug-in here:
http://kyticka.webzdarma.cz/3d/moi/#FullScreen
For the small scale problem - various operations in NURBS modeling are calculated to a tolerance level, like when 2 surfaces are intersected with each other the intersection is refined until it reaches a particular accuracy level and small objects can be impacted by this. I do have some changes in v4 coming to try and make small objects get the same proportional tolerance as "regular" objects and that may help with this area.
But it is kind of good in general to avoid working at small scales.
thanks for the fast response and explanation, makes sense. I also tried the plug-in and it kinda works. It goes to fullscreen but returns to a two column layout that wastes a lot of space (see attached). Is it maybe because I'm running the Modo theme?
Sven
Hi Sven, looks like the plug-in isn't working quite right with the scene browser in "inside" mode like you're using there. The other column that is showing is where the non-inside scene browser panel would be.
Try the one from here instead:
http://moi3d.com/forum/index.php?webtag=MOI&msg=5141.17
that did the trick. Thanks again!
Best,
Sven
Okay, last one (for now), just can't stop :)
Show messages: All
1-6
7-12
