3-22
23-27
yes, with the final point and without quotation marks.
So simply put the string with the point in a file called passphrase.txt, for example,
and then do a: convert bild.png -decipher passphrase.txt image.png
I'm curious, would this be equivalent to an encrypted, self extracting archive?
Well, a self-extracting and encrypted archive could contain anything,
while this is image "scrambling" so that nobody can see the real
content unless he / she has the passphrase.
Maybe this is good for Artist, wanting a bit of money from their
subscribers or if you have clients which you send images of
confidential rendered prototypes etc.
Sure, one can use encryption software like GnuPG to encrypt
things, also images etc, but this technique allows you to host
images instead of other data.
Thanks Stefan
Sorry I am very slow but.. (in Windows)
I suppose that is line command (that is a nightmare for me :)
so
bild.png is your image of the first post
pass.txt is a file with only "Hiergibtesnichtszusehen." (without "" inside)
both files are on the desktop
I put this in my Line command (Key Logo Windows + R) in windows 10
C:\Users\Pilou\Desktop\convert bild.png -decipher pass.txt image.png
and launch...
I have a message "convert is not found" !
When
C:\Users\Pilou\Desktop\bild.png -decipher pass.txt image.png
I have only your image of the first post at the screen and not image.png created
(who must i suppose different than the first image ? :)
There is something that i missed! :)
I have not installed anything more!
Suspense is intolerable! :)
PS And I am not sure that you have right "legally" to use such thing following country where you are ?
you made so far everything correct, but you missed to download and install
ImageMagick ... :-) Better i put next time also links for software i mention
in my postings ... , sorry!
The convert command is part of ImageMagick.
https://imagemagick.org/index.php
And for me there is no problem to use encryption tools, because i live
in Germany. I remember that a couple of years ago that for example
in France encryption was not allowed, but the French law has changed
in this respect, IIRC.
Best regards
Ok now maybe I must make something! :)
Rustic user slow minding like me must have all on the hands from start! :)
PS I have same problem with coder(s) of plugins for for MagicaVoxel...
That yet hard (for me) with line command and when you can't input inside this line command a path ".exe" i am totally losted!
I must wait some update even apparently that is yet working !
https://github.com/Zarbuz/SchematicToVox
Last function [Heightmap] Added new option : --color
By Zarbuz (very precise isn't it! Very cool result as aspected! )
PS a cool gallery!
http://www.fractal-recursions.com/files/mech0025.html
i took a quick look at the Voxel program, but i see that one needs
to compile it with Visual Studio, prior you get the required .exe file.
If i have time tomorrow i try to compile it and then give you a copy
via PM.
Normally it is not difficult to input a path for a program in cmd.exe
or Power Shell.
Regards And Good Night,
It's just that for a coder make that compilation you want to do tomorrow must be automatic ...for that alls users can be to use! ;)
But he don't direct think of rusted users! There is gap between coders and users! ;)
Previous versions has these compilation because i have screamed! :)
Always something missing! :)
Image Magick installed and tonne of docs readed...
i have put the image and passtext on the same folder than magick.exe
but ...
C:\Program Files\ImageMagick-7.0.8-Q16\magick.exe\convert bild.png -decipher pass.txt image.png
or
C:\Program Files\ImageMagick-7.0.8-Q16\magick.exe\magick convert bild.png -decipher pass.txt image.png
... for the moment any commands line...works!
the simple "magick pilou.jpg pilou.png" (without quote) who must change the format's image
(a pilou.jpg is existing in the folder of magick.exe !)
no error message but...where goes the result if maybe working...)
in a simple word how launch and where launch the "Command line tool" of Imagemagick ?
https://imagemagick.org/script/command-line-processing.php
https://imagemagick.org/script/command-line-tools.php#magick
are not helping for that (for me :)
What is your ultima secret? :)
the result should be the second image, like: convert bild.png -decipher passphrase.txt result.png.
And my ultimate secret is i am using a Mac... :-D (sorry, a joke :-))
Yes but that i want to know is "how to"! :)
For the moment anything works in Windows system!
Surrely a very little syntax and place to launch this poweful thing! :)
I don't see what I do more than to be inside the root folder of ImageMagick for launch the command line...???
Wait and see a Sherlock Holmes of the krosoft system! :)
normally when a program is installed you don't have to be in the root folder, afaik.
What happens if you are in cmd.exe and change (cd) do your Desktop folder and then
run the commands? Do you see then a new image file created on your Desktop?
I don't have ImageMagick installed currently on my Windows 7 Notebook, but i think
this should work.
i have compiled SchematicToVox for you. I send you a PM with the download link.
Please note, you need Tor Browser Bundle to download the files, because it is an
.onion link, which works only one time!
(P.S. i see when you have downloaded the file)
https://www.torproject.org
i forgot to include some .dll files, so now i have a new link, for everybody.
http://av6f2ci5nhz2shna.onion/quartered-predefine
I let this Tor Hidden Service run until this evening.
Hi Stefan,
All I see in the link are a lot of cooking recipes???
All links except Tor are inaccessible! :)
if you use the original Tor Browser Bundle, downloaded
from torproject.org, you should see this:
yes, because it is an .onion site... :-)
And have you tried the program and does it work?
i hope you downloaded the compiled program,
because im shutting down the service at 22.00 hrs.
3-22
23-27
