10-27
i took a quick look at the Voxel program, but i see that one needs
to compile it with Visual Studio, prior you get the required .exe file.
If i have time tomorrow i try to compile it and then give you a copy
via PM.
Normally it is not difficult to input a path for a program in cmd.exe
or Power Shell.
Regards And Good Night,
It's just that for a coder make that compilation you want to do tomorrow must be automatic ...for that alls users can be to use! ;)
But he don't direct think of rusted users! There is gap between coders and users! ;)
Previous versions has these compilation because i have screamed! :)
Always something missing! :)
Image Magick installed and tonne of docs readed...
i have put the image and passtext on the same folder than magick.exe
but ...
C:\Program Files\ImageMagick-7.0.8-Q16\magick.exe\convert bild.png -decipher pass.txt image.png
or
C:\Program Files\ImageMagick-7.0.8-Q16\magick.exe\magick convert bild.png -decipher pass.txt image.png
... for the moment any commands line...works!
the simple "magick pilou.jpg pilou.png" (without quote) who must change the format's image
(a pilou.jpg is existing in the folder of magick.exe !)
no error message but...where goes the result if maybe working...)
in a simple word how launch and where launch the "Command line tool" of Imagemagick ?
https://imagemagick.org/script/command-line-processing.php
https://imagemagick.org/script/command-line-tools.php#magick
are not helping for that (for me :)
What is your ultima secret? :)
the result should be the second image, like: convert bild.png -decipher passphrase.txt result.png.
And my ultimate secret is i am using a Mac... :-D (sorry, a joke :-))
Yes but that i want to know is "how to"! :)
For the moment anything works in Windows system!
Surrely a very little syntax and place to launch this poweful thing! :)
I don't see what I do more than to be inside the root folder of ImageMagick for launch the command line...???
Wait and see a Sherlock Holmes of the krosoft system! :)
normally when a program is installed you don't have to be in the root folder, afaik.
What happens if you are in cmd.exe and change (cd) do your Desktop folder and then
run the commands? Do you see then a new image file created on your Desktop?
I don't have ImageMagick installed currently on my Windows 7 Notebook, but i think
this should work.
i have compiled SchematicToVox for you. I send you a PM with the download link.
Please note, you need Tor Browser Bundle to download the files, because it is an
.onion link, which works only one time!
(P.S. i see when you have downloaded the file)
https://www.torproject.org
i forgot to include some .dll files, so now i have a new link, for everybody.
http://av6f2ci5nhz2shna.onion/quartered-predefine
I let this Tor Hidden Service run until this evening.
Hi Stefan,
All I see in the link are a lot of cooking recipes???
All links except Tor are inaccessible! :)
if you use the original Tor Browser Bundle, downloaded
from torproject.org, you should see this:
yes, because it is an .onion site... :-)
And have you tried the program and does it work?
i hope you downloaded the compiled program,
because im shutting down the service at 22.00 hrs.
Thank you Stefan.
(In Chrome, I guess I was looking at onion soup recipes :-))
Downloading TOR browser now.
Not sure about the time zones...It is 1PM here, 13:12 00. USA
The TOR link seems to be Dead...
sorry, already shutdown at 22.00 hrs CET.
But at least the community knows now how to host stuff from
their own computer securely with OnionShare.
https://onionshare.org
This might be useful too for freelancers exchanging confidential
prototype works for clients, for example. No learning curve required,
just drag and drop and people (clients) should be able to download
Tor Browser too.
Best Regards
Thank you Stefan,
I've got enough other projects to keep me busy...
Never heard of TOR before... have noticed other country bans... It is an interesting browser.
yes, the Tor project is very very good and interesting.
I ran for quite a long time a Tor relay, but later my
Server Provider increased the bandwidth charges,
so i had to close my relay, unfortunately.
P.S. For people who live in countries where Tor is
censored people in other free countries can set-up
Tor bridges, so that they can connect to them and
use Tor.
<< i hope you downloaded the compiled program
Alas no...inaccessible...but all that seems very complicated! :)
Tor...Onion...
Have you not a simple zip not oignoined, + Wetransfert by PM ? ;) (i am not warm to install all that new tools...)
https://wetransfer.com
https://www.7-zip.org incase of (but in zip classic) not the 7zip format)
I have surf about the web...run Imagemagick is not evident to install (or run something about it) on Windows!
Many users (like me) have problems! :)
I progress...no more error message but not decipher image.png created! ...
10-27
