Show messages: All
1-4
5-7
Hi Michael, just tried it and I get the same result
Hi Fred, your version there looks kind of weird it's missing all the line breaks. I guess maybe Max happened to make a text file that has UNIX type line endings which means it can't be edited properly in Notepad, you would need to use an editor that can understand those line endings like Notepad++.
What happens if you try the one attached below?
MiniSidepane.js
it worked! Construct and Transform are now in a single panel in V4
I'll remember to remove the startup file whenever it won't work anymore in future updates, maybe Max will have an updated version by then.
Thanks a lot
Show messages: All
1-4
5-7
