Thought it would be fun to share my scifi knife I made. I made it in the no save trial so it will only be remembered in png's :(
Is there a way to boost the anti-aliasing in Moi?
Hi FoxFire, great job it turned out nice.
Sorry no, not currently. Usually you would want to export to a rendering program to make a final quality image.
That's what I thought! But I chose the no save trial :(
Hi foxfire, one thing you can do is set up a shortcut key with a script that will generate a viewport image larger than the actual display. Then you could shrink that in an image processing program to get some antialiasing. Check out here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=3232.4
Thanks! I'll keep it in mind. I'm going to start using the 30 day trial now though, get into figuring out how to use it in my workflow.
