Show messages: All
1-6
7-8
Hi Axel, I think the problem is the period in your path (after St): F:\Modelle\St
. XYZ123\MOI\
Periods in file names are used to separate the name from the file extension, like filename.3dm - having one in the middle of the path will cause various file parsing mechanisms to get confused. With F:\Modelle\St. XYZ123\MOI\ it's going to think that the folder is at "F:\Modelle\" , the filename is "St" and the file extension is " XYZ123\MOI\" .
If you remove the period from the folder name it should probably solve the problem.
OMG...that easy! :-)
I could have found that culprit by myself! Luckily all other related files as drawings, etc. I properly named with a _ in between.
Thanks Michael!
Show messages: All
1-6
7-8
