Hi.
Is there a way to assign export to .OBJ to a key?
I have mapped F10 to Export command but it always defaults to .3dm
Since I have to export a lot of .OBJ files, would it be possible via a script to also select .OBJ?
Unfortunately, I have no scripting experience.
I have also looked in the moi.ini and found PersistSettingsBetweenSessions=y but this only remembers the Mesh Export options, not the file type as well.
I have also tried to create a Startup scene and while it retains the viewports, the export defaults to .3dm
Any help is appreciated. Thank you!
Hi Peticel, sorry there is not currently any way to set the file type dropdown in the file dialog by a shortcut key. I'll see about adding that in.
Hi Michael, thank you for the fast reply. You made a great program and the fact that you take the time to answer questions gives it a personal touch like nothing else I have used. Have a great day!
