Is it possible to add a script to an existing command ?
For example ; "Customrevolve + hide edges" So when triggering
this command by a hotkey it would hide the edges inmediately after revolving
a curve without the need of an extra keystroke.
Hi Tom, sorry no there isn't any way set up to run a command and then run some custom script after it all from within a shortcut key. You can trigger options and buttons that are in a command by giving parameters to a shortcut key but not general script. I'll see about adding a method for doing that.
