Show messages: All
1-9
10-12
Sorry I can't write script myself ! But if Max or other scripts' creators see your request...
Hi silverwoods, the regular "Orient" command, the one to the left of Line/Line can work like that.
Set the "Make copies" option and then you will be able to place many target points onto a surface, each target point will automatically align to the surface normal and there is a second stage where you can adjust the rotation, but if you do not want to do that you can just right click at that point. So you would just do a left click on the surface and then a right click anywhere in the viewport for each one.
Oh my... its wonderful! Thank you!
Show messages: All
1-9
10-12
