Show messages: All
1
2-7
Hi juraj,
Your problem seems to be "dimension" don't want mesure in certain zone of 3D view like a perp Z.
But with another zone it's seems possible.
An easy way is to do a "BooleanUnion" to have an edge. Then select your edge to know its dimension.
Of course you can next undo your BooleanUnion
By a supplement of search, I found that you have to change the view to finish in your case the dimension search.
Hi Phiro,
thanks a lot.
I knew I was missing some basic thing (union in this case).
What you mean by:
"I found that you have to change the view to finish in your case the dimension search."?
Also how did you do the explanation gif?
It's made out of video?
There is also a shortcut key script "CustomDistance" or "CustomDistancexyz2," for getting a single distance.
http://kyticka.webzdarma.cz/3d/moi/#MeasureDistance
thanks bemfarmer.
also quite useful plugin
Regards,
Juraj
Hi juraj,
I use Screenpresso for animated gif.
Regards,
P.
Show messages: All
1
2-7
