Show messages: All
1-4
5-10
Thanks Michael, just downloaded v4 and it works great :)
Seems to open much faster too!
Many thanks!
Gunter
One issue though Michael.. when I open an existing file, it appears as a wire frame. Then it randomly changes from wireframe to a full 3d image. Clicking in the pane seems to affect
this too.
Any solution to this?
Many thanks,
Gunter
Hi Gunter, what video card does your system have?
One thing you can try is to go to Options > General > "Edit .ini file" button and inside moi.ini in the [View] section find the line that has:
StaticBufferMaxVRAMToUseMB=
and set it to be =0 like this:
StaticBufferMaxVRAMToUseMB=0
That will disable the new part of the display engine that caches display meshes on the video card memory, from your description something is not working properly with that on your system.
As always, thank you for your super quick replies. Do you ever sleep? :)
This is what I have:
Sorry to be thick but how do I get to Options > General etc.? Also, I noticed that when you extrude a closed wire frame, it only extrudes the wire (like a plane) whereas previously it would etrude the whole shape. Does that make any sense?
Gunter
Hi hi, I found it... sorry Michael. Yes that seems to work now! Still unclear about the extrude difference though?
Many thanks,
Gunter
Resolved as well, apologies.
Thanks again,
Gunter
Show messages: All
1-4
5-10
