Show messages: All
1-5
6-8
For what it is worth, as I've never used 3DS Max: This link speaks of 3 ways to fix the normals in 3DS Max,
with either "reset normals", or "Break", or "Unify" command in 3DS Max:
https://forums.autodesk.com/t5/3ds-max-forum/model-gets-strange-black-grey-quot-shaded-quot-polys-and-it-just/td-p/4420379
-Brian
(Google search was "3dsmax import normals problem)
C4D is giving suspectly good result, because usually any other package will give you weird shading if you mess with the geometry at a vertex/poly level.
That's said 3Dsmax shading mess seems quite extreme here, like if vertex normal from the new added geo if just missing, or set at (0,0,0).
Yeah that does look like the vertex normals are ending up as 0,0,0 . But also having the entire polygon pitch black probably means the entire polygon's vertex normals are ending up as 0,0,0 - if it was only some vertices you'd probably see something more like black streaks emanating from the 0,0,0 ones.
Show messages: All
1-5
6-8
