I've defined a lot of shortcuts for MoI, and configured quite a few other settings. If I wanted to uninstall and then reinstall MoI, what do I need to backup and restore to get my shortcuts and settings back again?
Hi Stretch, the configuration is stored in the moi.ini file, you can find the path to it by clicking the button under Options > General > "Edit .ini file" . That will pop up a dialog showing the location of the moi.ini file.
It's not deleted when you uninstall though. But it is a good idea to back it up every once in a while though so you can restore it if needed.
