Show messages: All
1-12
13-20
Thanks Michael...
Message 9054.14 was deleted
This issue is something that I hit quite regularly.
Would it be possible to have the Mesh Angle value displayed somewhere on the ui?
Hi James, it would be possible to modify the UI to display it, where would you want to put it?
I'd generally recommend not to mess around with that setting much though since it can have bad side effects if set lower than the default 10 degrees.
Maybe between the options and the help at the bottom.
Hi James,
So to do that you'll need to edit the file CommandBar.htm which is inside MoI's ui sub-folder.
The options and help buttons are on line 137 of that file and look like this:
<moi:CommandButton icon="icons/OptionsIcon.png" onclick="if ( event.ctrlKey && event.shiftKey ) { LlamaMode(); } else { moi.ui.createDialog( 'Options.htm', 'resizeable,defaultWidth:43em,defaultHeight:32em' ); }"><moi:Text textid="Options"/></moi:CommandButton>
<moi:CommandSplitButton icon="icons/HelpIcon.png" menu="HelpMenu.htm" onclick="moi.launchHelp();"><moi:Text textid="Help"/></moi:CommandSplitButton>
To add a display of the mesh angle between them insert this new line in between them like so:
<div style="display:inline-block; margin:0.5em">Mesh angle:<moi:Text binding="this.innerText < moi.view.meshAngle"/></div>
Thanks Michael, works a treat!
Message 9054.20 was deleted
Show messages: All
1-12
13-20
