Full Version: V4 beta Aug-28-2018 available now
Show messages:  1-6  7-26  27-46  47-65
Message 9044.27 was deleted
2 Sep 2018   [#28]
Hi, I just wanted to report that in version 4 is not remembered the last directory all the times that I have to open a file I have to redo the path through the various directories, only if a file is saved in .3dm Moi format v4 remembers the last route used, with Version 3 this does not happen. Of course I must also say that I use Moi3D with Wine.
2 Sep 2018   [#29] In reply to [#28]
Hi pafurijaz, thank you for reporting the file open directory problem.
It seems like that may be a bug in Wine since normally on Windows the file dialog system code does the job of remembering the last used directory. It should not be difficult to make MoI do that itself when running on Wine though, I will look into that.
4 Sep 2018   [#30] In reply to [#1]
Hi!
Just a quick update concerning MoIV4 on Linux/wine, the object selection issue (as discussed earlier at http://moi3d.com/forum/messages.php?webtag=MOI&msg=8839.1) still exists for nvidia cards. I tested on Fedora 28 with nvidia driver 396.45.
best regards
Bernhard
5 Sep 2018   [#31]
I just noticed something and don't know if this is related to the MoI V4 beta or not, but as I've only installed the latest beta I thought to post it in this thread.
When I use the copy PDF to clipboard function (Top view, Fit to page), then paste it into Affinity Designer, the orientation of the pasted layer is tilted. You can see it in this combined screenshot:
5 Sep 2018   [#32] In reply to [#31]
Hi Metin, hmm that's interesting. I'm not aware of anything that MoI is setting in the PDF to make that happen, I'd think it's likely something that would need to be fixed in Affinity Designer.
I just tried it over here using MoI v4 and Affinity Designer v1.5.0.36 (on Windows) and I don't see that happening:
Do you have any other programs that can put a PDF on the clipboard to see what happens with them?
5 Sep 2018   [#33] In reply to [#32]
Indeed, when you copy a native MoI rectangle to the PDF clipboard, all is fine, but try the one in the attached MoI file.
A parent layer is automatically created in Affinity Designer, but you'll have to select the child layer (the actual shape).
The rectangle in the attached MoI file was created by:
1: Unwrapping Isocurves from a solid using UnwrapCurve.
2: Using Sweep to create a surface from the unwrapped U and V curves.
3: Selecting the edges of the surface and using Join to create a new closed rectangle.
Rectangle_PDF_clipboard.3dm
5 Sep 2018   [#34] In reply to [#33]
Hi Metin, thanks for posting the file. The difference with your rectangle there versus a newly drawn one is that 2 of the sides in that new one are cubic spline curves made up of 4 control points instead of just basic 2 point lines. Maybe that information will help the Affinity developers figure out what is causing that behavior in Affinity Designer.
Over here I still can't repeat that with your new file, I get this result - does this have the right thing selected in Affinity? Also do you get the same behavior if you save to a PDF file and use Place to insert it in Affinity instead of using the clipboard?
5 Sep 2018   [#35] In reply to [#33]
Hi Metin, I updated Affinity Designer to version 1.6.5.123 and I can now reproduce the rotated frame behavior when pasting into Affinity. It didn't happen in Affinity Designer version 1.5.0.36, so it looks like a regression in Affinity. I'd recommend sending a bug report to them describing the problem.
It may actually be a new feature though, the start point of the rectangle in the file you attached is in the bottom right corner and I guess they are using a line between the object centroid and its starting point as the initial rotation.
As far as I can see there isn't anything I can do in MoI to control that initial edit frame rotation in Affinity.
6 Sep 2018   [#36] In reply to [#35]
Many thanks for checking it out. I'll file a report at the Affinity Designer forum.
6 Sep 2018   [#37] In reply to [#35]
Issue reported at the Affinity Designer forum:
https://forum.affinity.serif.com/index.php?/topic/66630-pasted-pdf-from-clipboard-becomes-tilted-layer/
6 Sep 2018   [#38] In reply to [#24]
Names are lost when moving a file from MoI in Step format to Fusion as well.
9 Sep 2018   [#39]
Just wondering if it would be possible to add the function when opening other file types in MOI to keep the filename referenced as per opening a 3dm file. For example here is a typical job folder in which I use the STP file as a crossover to SOLIDWORKS from solidworks create individual parts which are then exported as DXFs for laser cutting manufacture. I sometimes need to add notes to the DXFs files rather than import and save as could these file be handled as native 3dm files.
thanks
Alex.
9 Sep 2018   [#40] In reply to [#39]
Hi Alex, so the reason why the current file name isn't set when you open something other than a .3dm file is that only .3dm files can contain everything that you create in MoI.
So for example if you open a .dxf file and then add a background image, if MoI set the current file name to that .dxf file and tried to save out to that same .dxf file when you closed MoI, it would appear to the user as if their background image was saved while in fact it was not.
But are you asking for MoI to save to a .3dm file in that situation and not the original opened file type? That seems like a little unusual file handling behavior to me but it could be possible to make an option to do that I think.
10 Sep 2018   [#41]
Here is a more clear example I have opened a DXF in MOI ( My default DXF Viewer) but when opened no reference to actual file is kept.
You can see when there are more parts to view the names can get lost if not referenced.
10 Sep 2018   [#42] In reply to [#41]
Hi Alex,
Yes, that's how it is intended to work. The reason why is because MoI will write to the current active file name when you use the Save command or when you exit MoI and choose "Save changes". But MoI is only able to save a subset of its possible information to a .dxf file so if you were to make something that MoI does not write to .dxf files you could end up thinking you had saved your complete work while actually only a subset was saved to the .dxf file.
To avoid that data loss scenario, MoI will only set the current file name when you open a .3dm file since that's the file format that MoI can store all of its information into.
10 Sep 2018   [#43]
Thanks for letting me know - in rhino if you import a file in a blank document it names that current file the import name then go save as it still keeps the filename as the first preference would at least this be possible?
thanks
Alex.
10 Sep 2018   [#44] In reply to [#43]
Hi Alex, so the thing that would be a little strange about that is this scenario - someone opens a .dxf file, works on it some and then closes MoI and pushes "Save changes" at the exit dialog. That would result in a new .3dm file being created and their original .dxf file would be unchanged which may be surprising.
I don't like to have surprising behavior in file handling so that's not something that I would want to have set up by default but I can make an option in moi.ini to enable that behavior.
11 Sep 2018   [#45]
If the same name function as per rhino file import is possible through the MOI ini file that would be great. Thanks for your assistance.
regards
Alex.
21 Sep 2018   [#46] In reply to [#35]
A quick update regarding the tilted PDF in Affinity Designer: the developers have just confirmed the issue and will look into it.
