What would be the command for Show Grid toggle under Grid Snap button?
Also, how do I find reference command for some UI buttons in the future?
Hi Fubax,
For toggling the grid put in the following as the command part of a shortcut key:
script: /* Toggle show grid */ moi.grid.display = !moi.grid.display;
There are several listed here:
http://moi3d.com/3.0/docs/moi_command_reference11.htm#shortcutkeys
If one you need isn't listed there then just post a question about it. To look it up directly you can also look at the definition of the button in .htm files inside the UI subfolder of MoI's main installation.
Thanks for the answer. I've also found some reference here
http://moi.maxsm.net/api/
