Full Version: Pattern on a Sphere
Show messages:  1-12  13-32  33-52  53-72  73-92  93-112  113-132  133-152  …  173-184
9 Aug 2018   [#73] In reply to [#72]
Thanks Marco,
>> Perfect as a kind of modern lamp!
Yes & herein lies my enthusiasm for Node Editor. Below is a couple of my pendant lamps.
Although these predate NE, my work is very much an exploration of the sculptural possibilities of parametric design, with a particular focus on lighting.
10 Aug 2018   [#74] In reply to [#73]
Hello James!
@You : "...Although these predate NE, my work is very much an exploration of the sculptural possibilities of parametric design, with a particular focus on lighting..."
I also love very much all is related with light. It's a very attractive "niche"!
12 Aug 2018   [#75]
wire 12XU
12 Aug 2018   [#76] In reply to [#75]
Super cool!
12 Aug 2018   [#77]
Hi James,
have you been a Punk in the seventies, like me, because of the title? ;-)
P.S: still have no time to submit something, sorry!
12 Aug 2018   [#78] In reply to [#77]
Hi Stefan,
Yes, I'm an Ex Lion Tamer.
https://www.youtube.com/watch?v=6nE8DFaxd94
:) James
13 Aug 2018   [#79]
Hi James,
cool! :-)
Message 9014.80 was deleted
15 Aug 2018   [#81] In reply to [#80]
Here I pace 3d objects with max's V Scripts.
15 Aug 2018   [#82]
Hi BurrMan,
very cool, i did not know those scripts.
15 Aug 2018   [#83]
Hi James,
the upholstered sphere looks really nice!
Message 9014.84 was deleted
15 Aug 2018   [#85]
Hi James,
now that is really cool, bravo! I had to look twice to find the "pole" areas... :-)
P.S. Googling for example for Goldberg spheres i figured out that i did those long time ago
with MoI and my MoI model is the first image. :-)
https://www.google.de/search?q=goldberg+sphere&tbm=isch&tbo=u&source=univ&sa=X&ved=2ahUKEwiglMXDh-_cAhVLEJoKHQmEAlsQsAR6BAgFEAE&biw=1173&bih=885
I think i make a flat surface only version, with colors.
15 Aug 2018   [#86]
Hello everyone!
WOW! ...what a wonderful things!!
Yes...Max's V Scripts "family" are really awesome!!
I have used them some year ago for the first time and they help me a lot in many situations!
16 Aug 2018   [#87]
Hi all,
my Goldberg (1,4) sphere re-modeled. Render maybe follows later.
g1_4
image hosting
16 Aug 2018   [#88] In reply to [#87]
Hi Stefan,
Beautifully done!
Can you please outline the steps to achieve this result.
Much appreciated
16 Aug 2018   [#89]
Hi James,
thanks. Sure, i will show the steps required to create Goldberg spheres with MoI when i come home this afternoon,
because it requires addional free software and i don't have currently the link (and other infos) handy.
I hope i can do so around 16-17 pm CET.
16 Aug 2018   [#90] In reply to [#89]
Excellent pattern, Stefan!
Respect.
Mik
16 Aug 2018   [#91]
Thanks Mik.
Hi James,
a small tut, with no pictures, but i hope
it is easy to understand.
Quote user genna87 from Reddit posting:
"With Antiprism you can generate any Goldberg polyhedron:
geodesic -c m,n ico | pol_recip | canonical | off_util -g | off2obj > /path/to/file.obj
m,n is the desired class ( eg: 4,0 )"
http://antiprism.com
I used for m,n = 1,4 like shown in Wikipedia:
https://en.wikipedia.org/wiki/Goldberg_polyhedron
Once you have the polyhedron import it with obj import script
and then create a slightly smaller solid sphere near the polyhedron
and additionally place also one point object in the scene.
After that align all three objects, so that they are centered
and copy/paste the edges from the polyhedron. Then do a point
extrusion (no caps) with the obtained lines and the centered point.
Use the generated surfaces to trim the solid sphere.
Now you have a Goldberg pattern on your sphere, which you
can then colorize with MoI.
That's all. :-)
P.S. since i'm no Math geek like you and others i have to
check out why i have problems with creating a Class II
polyhedron.
16 Aug 2018   [#92]
...same sphere with different colorization and seam removed.
Bildschirmfoto_2018-08-16_um_22.31.35
bild für foren hochladen
