Full Version: coordinates of a point
29 Jun 2018   [#1]
Hi guys,
I wanted to know how I can retrieve the X, Y, Z coordinates of a point
thank you
29 Jun 2018   [#2] In reply to [#1]
Hi Tony77,
Someone wrote script for this "_PointCoordinates3".
Might do a search for that.
Michael T.
29 Jun 2018   [#3] In reply to [#2]
Here it is:
http://moi3d.com/forum/index.php?webtag=MOI&msg=7457.14
also this one may be interesting:
http://moi3d.com/forum/index.php?webtag=MOI&msg=6257.29
and...
http://moi3d.com/forum/index.php?webtag=MOI&msg=8859.26
Good luck!
Franz
29 Jun 2018   [#4] In reply to [#1]
Hi Tony, one method is to use any drawing command that picks points and then watch what the XYZ field in the bottom toolbar shows when you snap onto it.
The script that Michael T. mentions is available here: http://moi3d.com/forum/index.php?webtag=MOI&msg=7457.14 and instructions for installing plugins are in the FAQ here: http://moi3d.com/faq#Q:_How_do_I_install_a_plug-in_script.3F
29 Jun 2018   [#5]
Thank you so much guys
a last question how do you use the scripts? ..... what is the procedure to use them?
with keyboard shortcuts or something else?
29 Jun 2018   [#6] In reply to [#5]
Ok I understand .... thanks again :)
30 Jun 2018   [#7] In reply to [#6]
Hi guys
sorry for the trouble but I have a problem, exceeded that of the coordinates of the points I need to measure the angles of the triangle that has the vertices with various heights in Z as you can see from the figure.
If I project on the plane C the figure can safely but I have noticed that I lose obviously the proportion of the triangle.
how can I measure the angles of the triangle with the vertices with the values of the different vertices?
30 Jun 2018   [#8] In reply to [#7]
Michael's Angle script is here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=5390.3
30 Jun 2018   [#9] In reply to [#7]
Hi!
Now I've tried - also a possibility:
Max Smirnov's script "PointsOnCurve" still has a nice function to get coordinates of points,
and angles with script _Dimensions (Max).
http://moi3d.com/forum/index.php?webtag=MOI&msg=7403.1
Franz
