Hi all ...
I know this has been asked many times before so please excuse my ignorance.
For some reason my "dimension" short cut key stopped working so I guess I have to do a reinstall of some kind.
I just downloaded the most recent version but don't know where to put it (the script that is).
I found the moi.ini file but that does not look like the place the scripts are located.
I have done this previously but now I have a 'senior's moment' and don't remember how to install this.
Thanks for help.
eric
Hi eric, this is for MoI v4 - press the Windows key on your keyboard to open up the Start menu and then type %appdata%\Moi and push enter. That will open up your appdata folder and then it's the commands folder inside there that you need to copy the unzipped files into.
If you put them there, then you won't have to repeat this for new beta releases anymore.
Hi Michael ...
Thanks ... I got it working after a couple of false starts.
I am looking forward to when you can get to built in dimension functions.
cheers,
eric
