I've added the screenshot shortcut, but is there any way to export higher quality images? I have a large file so i have had to turn down the mesh angle so the screenshot does not come out as well as it could. Thanks
Henry
Hi Henry, which screenshot shortcut are you using? There are a couple of different ones - one takes a screenshot of what is right on the monitor while the other one generates an image to an off screen buffer and so can be a higher resolution than your monitor.
It could also be possible to make your shortcut tighten up the mesh angle, then do the screenshot, and then set the mesh angle back again. This will cause the display meshes to be generated 2 times and so will take a bit of time.
Another thing you could try is saving to PDF format and using the Adobe PDF viewer to make an image of the PDF. The shaded image generated by the PDF export has a custom mesh generated for it and isn't limited by the display mesh angle setting.
