Show messages: All
1-2
3-8
O.k. and here a start with 2D colored triangles. For this i created
a hex grid with all number from 0-255 in hex notation. The colors
of the triangles are simple the decimal values of the coordinates
of each triangle input in MoI's color picker.
Later when all triangles are created and in case smaller ones
fall under larger ones i will calculate the surface area of each
triangle an put the smallers on on top and the larger ones behind.
Hello Stefan!
Very interesting and peculiar things...
Thanks!
Hi Marco,
yes, it is imho interesting to visualize hash data or fingerprints,
because it is easier for humans to detect differences in
images and they can be easier memorized.
The Bitmessage software is such an example, where
each user has an identicon, based on the key data.
Mmmhhh, i did not thought about that coordinates from the hash can also
form a straight line, instead of a triangle. So i have now one straight line
from the coordinates b0,8f,9a...
So when doing a final rendering i must form a long skinny surface from
that straight closed line.
Here is what i have so far, in an unsorted order:
Original stuff, Stefan!
Thanks Metin!
Show messages: All
1-2
3-8
