Is it possible to copy Illustrator shape and paste in MoI in front view instead on right ?
for the moment I rotate in the right view but it will be easier to have directly my vector path in front
thanks
Hi Finema, when you paste from Illustrator it should come in to MoI on the Top view x/y plane. After you've pasted a quick way to get it to a different view is to run the OrientViewToView command, which is under Transform > Orient > View/View. In that OrientViewToView command, click once anywhere inside the Top view then next click anywhere in the Front view, that will move that stuff from Top to Front.
It's perfect Michael.
Thanks a lot.
