Hi. I need to draw this model: a simple sheet of A4 rolled to form a sort of cornet. The dimensions need to be exact, once in form, to the same sheet of paper. (If i develop the surface, the dimensions stays the same A4). I tried a lot of things, with no success. I'm stuck with this. Do you guys have some ideas? What do i need to begin with?
Moujiik
UnwrapCurve for be sure of the length of your curves curvated
http://moi3d.com/forum/messages.php?webtag=MOI&msg=5136.1
or a simple click on curve gives the length also in the right corner page! ;)
Else a simple Network beteen 4 curves must make the trick! :)
Ok, thank you Pilou for the unwrap curve. I know now that i don't need the precision i'd ask. It is a twisted model with a false perspective.
Moujiik
