20-27
Hi guys. I've made some re-arrangement in the ui and thought I'd share it.
I expanded all commands into a single scrollable area, with a thin webkit scrollbar and moved the command options to the top of the browser pane.
I also moved some buttons around and changed a few icons. Hope you like it.
As always BACK-UP your installation files before you try it!
ui.rar
Hello immortalx!
I Like hotkeys and almost no visible icons but your it's a very nice layout! Thanks.
Hi immortalx,
Very good attempt. If you can hide the names of tool, the UI will be more concise. Thanks for sharing!
Thanks guys! The tool descriptions can be removed by either deleting all the <Moi Text> tags in SidePane.htm, or simply by commenting out the respective strings in EnglishStrings.txt.
Here's another option with an additional bar at the bottom which hosts all the curves/solids and a narrower, less busy sidepane.
ui.rar
A reversed expanded one! :)
Thanks for sharing this wonderful UI. What I mean is to hide the tool description. When you hover your mouse over the tool, you can display tooltip labels. I have always had this idea.
like this:
@Pilou
If I understand what you mean, then replace your MainWindowLayout.xml with the attached file.
@Yuan
That's a pretty interesting idea! Give me a day or two (it's holiday here today) and I'll convert all tool descriptions to tooltips.
@Yuan
Here you go, tell me if anything is wrong.
Replace the files in ui folder with the ones in the attachement.
ui_tooltips.rar
Yes but my comment was just on the description of the position of bottom menus go to the top
and all menus functions were "expanded"! ;)
For the minimum width of classic menu you can open the French UI : there is smaller than the English one! (some pixels)
Yes it's a sort of task that I made for the fun! :)
Ah ok, now I understand Pilou!
Hi immortalx,
good nice! Can you tell me the method of tool descriptions to tooltips? Need to modify those files?
-Yuan
@Yuan
Browse to the ui folder and edit the SidePane, BottomBar and CommandBar files. Inside you'll find several "blocks" of lines all of which has a section like this:
title = "tool description"
"tool description" will be different for every tool or interface button of course. Just edit the part inside the quotes and you're set.
Remember to back up your files first!
Hi immortalx,
I have changed it according to the method you teach.Thank you very much!
Hi immortalx,
how can i get the missing Buttons for Obj Library, Ext Scripts and Snapshot?
Thank you
-moritz
@MORITZ
You have to edit CommandBar.htm and add this line:
<script type="text/javascript" src="customui/CustomInit.js">
Scroll through the file and search for this block:
<vcenter>
<moi:StateButton
binding="value = moi.drawingAids.objectSnap"
menu="ObjectSnapMenu.htm">
<moi:Text textid="Object Snap">
</moi:StateButton>
</vcenter>
<moi:Spacer>
Add the above line immediately after <moi:Spacer>
Hi Moritz,
Those are from Max's CustomUI extension, you can find it here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=6507.1
Hello Michael, hello immortalx,
in my current CustomUI I already have these buttons and they work. The question was rather: "How do I get the buttons (included in the version of Max) into the UI of immortalx"?
My knowledge of HTML is not exactly record-breaking.
Many thanks to you both and also to Max for your wonderful development work.
-moritz
Hi moritz, well you'll need to do something like examine the differences between the standard UI and Max's custom ui, then apply the same modification to immortalx's UI.
Please note that all these custom UI setups are not a standard part of MoI and aren't something that I'm focused on supporting myself.
I can try to give you some hints to help you figure it out, maybe a first step would be if you could post more detailed information like which version of MoI you're trying to do this to and which version of Max's CustomUI you are using and what operating system you're running on.
I just want to emphasize and support what Michael has just mentioned.
It's extremely difficult for a developer to support non standard customization to his/her application. We should all be thankful in the first place, that we are actually able to do that, and everyone trying these custom modifications should be well aware that they can break the application's functionality.
With that said (and although I've no previous HTML knowledge, just general programming background) you are welcome to ask me anything for this custom ui and I'll do my best (if I can) to make it happen :)
Hello Michael,
I am using Max' CustomUI.2.0.beta1 with MoI V4 and a MacPro 5.1 with OS X 10.10.5
- moritz
20-27
