Show messages: All
1
2-3
PS: I use latest build (Februar 2018) and I'm on German OS. So normally I have to write 0.001 in Moi, even if OS should do it as 0,001 (no point!). If that helps.
Hi Robert, what file format are you using for transferring into Modo?
I'd usually recommend using LWO format for that, and setting the "Scale output units to meters" option in MoI under Options > Import/Export > LWO options.
Re: decimal point separator, are you seeing that MoI v4 for Mac is behaving differently than MoI v3 Mac for this? I mean does v3 display using a comma for the separator while v4 displays numbers using a point ?
Show messages: All
1
2-3
