Show messages: All
1-3
4-10
Hi Jeff,
> So when we rotate, moi just transforms the vertices?
Yes, that's correct.
But if you are able to attach some additional node objects to each main object instead of doing a cube if you did a 3 orthogonal lines one for x, one for y, one for z, that might be workable.
For importing into Unity, I think it ignores points and lines.
Only meshes are imported. So maybe three triangles in the form of a corner to represent the axes.
Jeff.
There is a solidworks to urdf exporter:
http://wiki.ros.org/Industrial/Tutorials/Create%20a%20URDF%20for%20an%20Industrial%20Robot
- B
Hi Jeff, sorry I'm not understanding the part about importing into Unity - I thought you needed to write the rotation information into an XML file.
sorry for the confusion - I have URDF which I use for the physics engine import, but
I also to import robot models into Unity using URDF for easy visualization and PBR rendering.
(you can see some examples at my website
www.spryrobotics.com).
Jeff.
Cool!
https://vimeo.com/245327854
Show messages: All
1-3
4-10
