Full Version: Off-topic — ZBrush 2018
Show messages:  1-2  3-22  23-33
28 Mar 2018   [#3] In reply to [#2]
Haha, yes, Pilou, they keep you busy! :D
By the way, how do you embed video in this forum? I've tried embed src="https://www.youtube.com/watch?v=FZYeHlwMCCM" / (between < and>, but to no effect).
28 Mar 2018   [#4]
No! In Youtube (corner bottom right) : Share / Embed / Embed Video and Copy past all lines with some options if you want! ;)
You can also on the Youtube Video : Right Click / Copy embed code! ;)
Don't work on any forum!
28 Mar 2018   [#5] In reply to [#4]
Merci beaucoup, Pilou! It works. :)
28 Mar 2018   [#6]
I was pretty impressed by their live presentation, yesterday.
Can't wait to play with it. Wish i had bought ZBrush a couple
of years earlier... Amazing that they still give out free upgrades
and now also cross-platform usage!
I hope that one day they implement two features from 3DCoat,
namely the so-called bas-relief feature and the Image to Mesh
feature. Then i can send 3DCoat safely to /dev/null... :-)
It's also amazing what new features they come up with, with every
release. One may think now i have all cool features and then they
always surprise you with new features other 3D apps don't have.
28 Mar 2018   [#7] In reply to [#6]
ZBrush does have image to mesh, its called Alpha Skinning http://docs.pixologic.com/reference-guide/alpha/make-3d/
28 Mar 2018   [#8]
Hi Chris,
yes, maybe i have not properly explained what i like to have.
I like to use a color image with that process too, to get the
fractals, i have created in my gallery. In 3DCoat i simply
use a b/w (or color) bump map and a b/w mask and on top a color
image, which then gets converted to vertex colors. A very
easy, one minute process, in 3DCoat. Maybe i have to look
deeper into ZBrush to find a similar and fast workflow, which
i may have overlooked.
28 Mar 2018   [#9] In reply to [#8]
I don't know ZBrush as well as I would like ... Offhand I'd say that would be a separate step.
I think its possible to use a texture map to poly paint the vertices. It would be nice if it did it the mesh and color in one step ... load an alpha/displacement image and a color image and you're done.
28 Mar 2018   [#10]
Cool, vertex colors from 3DCoat come now in, via the regular .obj importer. :-)
Bildschirmfoto_2018-03-28_um_21.41.36
28 Mar 2018   [#11] In reply to [#3]
<they keep you busy
@ Metin
In fact that is yet made!
A very smart site! :)
http://pixologic.com/features/
There are different languages with a menu! :)
(click on top right corner page)
29 Mar 2018   [#12]
For those of you who also use ZBrush: I've created a composition of the most important default Preferences settings, as a reference:
http://www.metinseven.com/blog/4pdX/zbrush-2018-default-preferences
29 Mar 2018   [#13] In reply to [#12]
ZB 2018
Not yet loaded but the great thing for French people is that is in French since the previous release! :)
1 Apr 2018   [#14] In reply to [#6]
Hi Stefan,
There's already a function similar to Bas Relief in ZBrush: the Flatten Deformer...
1 Apr 2018   [#15]
Hi Metin,
thanks, i had not time yet to look into the new tools, ZBrush offers.
Will look at it, but i have a little doubt that one can get a proper
bas relief from that.
1 Apr 2018   [#16]
BTW: regarding bas reliefs with ZBrush....
i already ask a while ago the author, #AskZbrush and asked also
at CGTalk, but nobody could explain to me how to do that properly
with ZBrush... (like the dragon model)
http://www.zbrushcentral.com/showthread.php?185811-Bas-Relief-amp-Other-Works
1 Apr 2018   [#17] In reply to [#16]
Hi Stefan,
I would first create an alpha texture from the 3D model, then stamp the alpha onto the 3D shape you want it to be on, in a very high polygon resolution, to maintain all detail.
1 Apr 2018   [#18]
I've been playing with Sculptris Pro dynamic tesselation mode this morning, here's my first freestyle sculpture. No reference used, I've just been playing around. Sculptris Pro works very pleasantly.
1 Apr 2018   [#19]
The Top raw gallery of Zbrush is an amazing collection of true Master pieces!
http://www.zbrushcentral.com/zbc-top-row-gallery.php
Over 15 years and alas not all old pictures are not more obtainable! :(
The dancer by Xioa Ming
1 Apr 2018   [#20]
Hi Metin,
yes, alphas could be a gould start, depending how they look like... because they usually
give also the straight extrusions at the models silhouette.
Nice model Metin, looks like you have fun with Sculptris Pro! :-)
2 Apr 2018   [#21] In reply to [#20]
Thanks Stefan!
For complex relief ZBrush offers Vector Displacement Brushes, which include overlapping:
http://docs.pixologic.com/user-guide/3d-modeling/exporting-your-model/vector-displacement-maps/
2 Apr 2018   [#22]
Hi Metin,
i think this is also not good, because you need already a bas relief in order to convert
it to Vector Displacement...
Anyways, thanks for your suggestions. Maybe one day someone can lift the secret
described in the ZBrush thread, i have posted. ;-)
