Full Version: Off-topic — ZBrush 2018
Show messages:  1-2  3-22  23-33
2 Apr 2018   [#23] In reply to [#22]
Can you describe in detail your problem about the "Dragon bas relief" and what do you want to know!
I ask that to my friend who works at Pixologic! ;)
It's not pure sculpting ?
2 Apr 2018   [#24]
thanks for your help, much appreciated!
The author says that he used ZProject brush to get the bas relief, but i wonder how he
does this with ZProject, because the dragon bas relief is pretty flat, compared to the
original model. When one uses ZProject he usually projects the mesh on a plane with
the same height and not so flat. Someone on Twitter told me to use the settings -100
but that had no impact when i tried it. There must be some easy? step, which i am not
aware of.
Also i don't understand how he managed to ZProject the top sphere with the two stripes
on the tail, which is more off Z then the dragon, so that it sits perfectly on the tail, without
extrusions.
2 Apr 2018   [#25] In reply to [#24]
I believe its necessary to modify the model to provide a workable bas-relief. Some models may work with little or no modification but in general I think it is not a push button task to go from model to relief.
2 Apr 2018   [#26] In reply to [#24]
Send it! Wait and see! :)
2 Apr 2018   [#27]
@chris: The author mentioned only ZProject and did not explain how
he did it with ZProject.
@Pilou: Thanks a lot!
3 Apr 2018   [#28] In reply to [#27]
@Stefan
My friend is overwhelmed with work so just some speed advices! ;)
Be careful when you make bas relief, in general you prepare the model that will serve as a support for the projection accordingly, i.e. be careful that it is as much as possible in a single plane.
It is not impossible that the artist applied some transformations, see dynameshed his model just before making his projection.
Moreover I admit that I will tend to make a projection of SubTool and eventually use the brush ZProject to eventually make touch-ups.
It should not be forgotten that ZProject also works with ALT depending on the position of the model and the projection...
Hope this can help a few...
3 Apr 2018   [#29]
thanks for the informations from you friend!
It looks like from his desrciption that severeal steps are involved, as Chris mentioned too.
So i have to see if i can come up with something in the future, when using ZBrush.
4 Apr 2018   [#30]
Fabulous!
http://www.zbrushcentral.com/showthread.php?211750-Digital-sculpts-for-the-falla-Na-Jordana-2018&p=1230069&viewfull=1#post1230069
http://pixologic.com/interview/fallas/index.php (5 pages)
6 Apr 2018   [#31]
Intensive use of the "ZModeler" (another world of mechanical sculpting )
: use the actual rectangular menu is some cerebral painfull - seems will be more fun if it's will be "radial" :) ...
https://pixelprotest.com/projects/45-days-of-zbrush/
6 Apr 2018   [#32]
Pretty awesome!
Thanks for posting this, Pilou!
6 Apr 2018   [#33]
That's a very nice update, the snake brush with Sculptris mode is quite impressive.
Marc
