Show messages: All
1-12
13-16
Hi Alberto!
Thanks for your reply.
Unfortunately, I haven't had any time lately...
Now I tried again, could download the file.
Again with a message for Windows..., but I think it is a spam-message.
(-Windows is infected with viruses and other malicious applications.
Viruses must be removed and system damage repaired
It is first necessary to remove the virus immediately. Mte drive you up
"If you leave this page your Windows remains corrupted and vulnerable"-)
But my attempt to play the "Seat Rotation.dm" didn't succeed, I got no "RUN".
I tried 'nodeeditor.v.1.0.rc3.2018.03.09", the last version of the node editor(*Seat Rot.jpg).
But also "nodeeditor.v.0.85" and "nodeeditor.v.0.99.2017.12.18" did not run, I lost connections
from speed stard and end.
I think, that I make a lot of things wrong.
Can you give me a tip on how best (and slowly) to learn the functions of the nodeeditor?
It really seems to be a very interesting but complex subject.
Franz
Hi Franz
in the file two nodes are highlighted in red,
GetCrv Frame and Quartz2 ,
obviously you do not have these two nodes in the Extension folder,
inside the Nodeeditor Container-
The file personally
I did it with the 1.0 rc2 version
the exstensions to update I enclose them a this link :
http://www.mediafire.com/file/3s7tjc7ihyam5yf/Extension_v1.0_rc2.zip
are Points 2 and rd2 (if you want you can insert the whole Extension folder, instead of just these two ..... as you want)
Without this everything should work ...
Have a nice day
alberto
NB
Lastly
to enable rotation, you must connect the quartz2 output
at the entrance of the last Switch active-
Hi alberto!
Thanks for your reply, i tried it, but I think may be im wrong or dont have some nodes or funktions.
Here some screenshots:
Have a nice day,
Franz
Hi Franz
now the nodes are all ok
I have attached some images to this link:
http://www.mediafire.com/file/pzxg8p01ajxiyl8/Seater_Rotation_Picture.zip
To start the movement, the last Switch node , that
connected at the exit with the Seat rotation node,
it must be set up, that is, in line with the exit of the node
Quartz 2-
See image 3
I hope everything is clear......
have a nice day
alberto
Show messages: All
1-12
13-16
