I upgraded to High Sierra today, but MoI refuses to work. Starts up, but leaves a big white rectangle behind which everything disappears, even after force quitting MoI. Cursor and apps are invisible behind it, only rebooting or logging out/in makes everything back to normal.
I Unchecked the option for "Auto Detect GPU info for Direct3D" in Wineskin, and tried some other options too in this app, but no result.
any other things I can try to get it to work?
thanks,
wim
Hi wim, what version of MoI are you using? If it isn't the latest version 3.2 you should first try updating to that which you can get from here:
http://moi3d.com/reinstall.htm . You could also use the v4 beta version which you can get from
http://moi3d.com/beta.htm .
it is 3.1, so that will be it. I probably took the wrong version from my backup. (did a clean install after reformatting the disk).
thanks!
wim
Works!
w
Hi Michael, I followed your link .../reinstall.htm but the download was a MOI3.0 setup with most files dated of Sept2014. Maybe it's the 3.2 version but when having a look to the HELP buttom also 3.0 is shown. It would be great to get a brief info if I Do something wrong and if what I need to do to get the ver3.2, thanks!
Joerg
Hi Joerg, the current v3 version for the Windows version is 3.0 . The newer version 3.2 is only for the Mac release, it has some changes to fix issues with running on recent Mac operating systems.
The newest available version is the v4 beta release which you can get from
Hi Michael, ahh the Mac-version, for me it's Windows. Thanks a lot for the information!!!!
Joerg
