I'm sure someone will find a use for this:
https://spotify.github.io/coordinator/
It's an open-source project by Spotify that takes an SVG file and subsequently lets you finetune the dot placement. You can save the result as (X,Y) coordinates (both CSV as well as JSON), or as a PNG image. I haven't tested this, but the ImportPointFile from
http://moi3d.com/forum/index.php?webtag=MOI&msg=5124.2 should be able to import the generated CSV data into MOI.
More info here:
https://labs.spotify.com/2018/03/02/introducing-coordinator-a-new-open-source-project-made-at-spotify-to-inject-some-whimsy-into-data-visualizations/
Hello Fabien,
it works perfectly with VoronoiScript.
Thank you very much
moritz
Awesome, thanks a lot for sharing!
Just downloaded and installed it.
Very cool, thanks Fabien!
Hi all,
just had a little bit time to test this tool with Max's script.
The points come in upside down, but no problem.
Test image, a butterfly tribal tattoo .svg from vectorportal.com.
Wanderful!!!
I guess you can do a very nice rendering with this subject :)
Hi Marco,
thanks.
I think with the right subject and Max's script a lot of things are possible,
for people making nice looking images.
Cool result Stefan!
A bit of testing of offsets:
Thanks danperk,
i see you have also lot's of fun! :-)
Your text examples looks nice! I'm currently also learning more
about classic typography and maybe i find a good combination with
typography and Max's script too, were the Voronoi structure blends
nicely with classical (3D) typefaces.
Seems very cool! Bravo for the discovery!
