I have one recurring problem with models I create for friends (for 3D printing). Usually they want to have the model enlarged or changed but as soon as I have added filets on the edges of an object I can't modify it easily. Is there a way around this?
This image(s) describe my actual problem. I'd like to make the box wider but I already have a filet which is in the way.
Make a box a little little more biggest overlaped the existing fillet
Bolean Union with existing
Remake Fillet ;)
More easy than this! But not a very big deal...(read Right to Left)
here the Script!
http://moi3d.com/forum/index.php?webtag=MOI&msg=5931.1
I've made several MoI models for my 3D Printer, and changes are always necessary.
I just keep all my construction lines / curves and rebuild the model. To me it's a lot faster than trying to fix it.
I also duplicate and keep intermediate versions of my work within the same file. For example, I keep a version prior to adding fillets, making holes, etc. That way I can make modifications easily.
Hello Ed.
@You : "...I just keep all my construction lines / curves and rebuild the model.
I totally agree with this point of view.
It's also my "style".
Hi Nico, yes I'd also recommend saving a version of your model before applying fillets, so you can go back to the pre-filleted state more easily later on.
Thanks for the suggestions guys. I was able to fix my model. Sadly the script didn't work because the subsequent removal of faces broke some other faces (not the fault of the script - probably the geometry of my object). But I was able to delete the round edges and rebuild them with the help of lines and the planar feature. And I remembered to save a backup without filets this time :)
One other thing I learned. Sometimes when I create filets, they look broken because their size conflicts with the adjacent edges. If I go ahead and accept the "broken" filet, then I can still make it work by selecting the model and the broken filet and doing a boolean merge. Then I can delete the additional remains and have my filet.
Hi Nicolinux!
Thanks for sharing your good idea !
Franz
