Full Version: Convert Control Points to Points ?
Show messages:  1-4  5-24  25-44  45-59
12 Mar 2018   [#45]
I thought you have it already on your computer... because you already made things with it and posted here... :-)
12 Mar 2018   [#46] In reply to [#45]
Huhu : I had JDSoft-ArtSoft : I believed Artsoft "alone" was another one! :)
12 Mar 2018   [#47] In reply to [#43]
Hi Stefan!
I will try it in your way, here is the wanted function in Qcad (DXF):
So export the curve to DXF, edit it in Qcad and import it again, if you like.
But I think they drew the points earlier in Moi.
Franz
12 Mar 2018   [#48]
Hi Franz,
i also played today with HeeksCAD and it has the function to automatically
create a spline curve from points! :-) But i could not figure out yet how to edit
splines in there and also how to export as step or iges, because no files were written.
Later then i found PolyCAD which also looks very interesting but i have to wait for
the serial.
12 Mar 2018   [#49] In reply to [#48]
Don't really understand if it's entierelly free or not ?
In any case seems terrific for boat's hull!
13 Mar 2018   [#50]
yes, it is free, but you must register the software.
13 Mar 2018   [#51] In reply to [#49]
YES: PolyCAD is free:::
http://www.polycad.co.uk
regards
O.
13 Mar 2018   [#52]
Thanks! I have a mail from the author Marcus Bole
but alas i had not my glasses when I sent him the Computer key number machine, so i must make it again! :)
PS He don't know Moi3D! So a cool discovery for him!
13 Mar 2018   [#53] In reply to [#42]
Hi Stefan!
Thanks for the tip with ArtForm (3.5).
In my version I cannot import *.3dm, only IGES.
Connot finde in "Curve Edit" the way to /Modify/Modify Point on Curve.
And I had to learn more about working with ArtForm, so I cannot edit points from the curve now.
Sorry, I will try later.
Franz
13 Mar 2018   [#54] In reply to [#53]
Hi Franz,
no problem. In order to do that you have to be in the NURBS Modeler module.
NURBSmodule
13 Mar 2018   [#55]
...and right Click on the canvas when you have select what you want and how export! ;)
The format 3dm appears in the popup menu of file saving.
13 Mar 2018   [#56] In reply to [#54]
Hi Stefan!
Thank`s for your help.
I see, it ist really possible with these "sidestep" to ArtForm, to change the curve form with curve points and reimport to moi very quick!
Franz :)!
13 Mar 2018   [#57]
Hi Franz,
:-) yes! ArtForm and MoI is IHMO a very good combination.
13 Mar 2018   [#58]
Very cool!
Format IGES in the 2 ways for Moi3D!
So cool for Zebra surface examination!
25 Mar 2018   [#59]
Hocked by PolyCAD I am making the French Site adaption! (will be heavy for sure) :D
A cool thing for understand in deepth this nurbs naval technic!
http://moiscript.weebly.com/polycad1.html
In Moi a cool technic is this one! ;)
http://moiscript.weebly.com/deacuteplacer-des-objets.html
