Full Version: Origami Simulator Online!
Show messages: All  1-4  5-11
12 Mar 2018   [#5]
I will try to see how Moi3D can make the "Flat" Illustrator part! ;)
PS French version of the Manual donel! ;)
http://moiscript.weebly.com/origami-simulator.html
12 Mar 2018   [#6]
If you explore the site of Amanda you will find some crazzy things!
Maze Folder, an app by Erik Demaine, Martin Demaine, and Jason Ku that creates crease patterns for any raised maze on a square grid.
Based on the paper Folding Any Orthogonal Maze : http://erikdemaine.org/papers/MazeFolding_Origami5/paper.pdf
http://martindemaine.org/
http://jasonku.mit.edu/
http://erikdemaine.org/fonts/maze/
13 Mar 2018   [#7] In reply to [#6]
Astonishing!!!
Thanks Pilou!
13 Mar 2018   [#8]
After some try :)
- You can draw directly in Moi3D (works with the colors given by default! Black, Blue, Red, Magenta, Green - you must create a new one for Yellow)
- Export as PDF (view Top)
- Open inside the free Gravit Designer https://www.designer.io (View / Fit Canvas)
- Save as SVG File ( file must have small letters for the extension .SVG so .svg :)
You can now use the Origami Simulator Online and Import the file .svg
Here Fold Percent was limited to 60 % (in Origami Simulator itself - advanced Options )
Some Draw Lines in Moi, an edge is selected to verify its color!
You can play with opacity for the angle of folding (Mountain / Valley)
View of the PDF file from Moi
13 Mar 2018   [#9]
Hi Pilou
Big Shot ,very very cool
thanks
alberto
13 Mar 2018   [#10]
For unfold a Moi's volume maybe the free FormZ Free can help you! :)
http://www.formz.com/products/formzfree.html
Minutes 24 -->
13 Mar 2018   [#11]
Origami Simulator will fine for animation of Hull boats!
