Show messages: All
1-2
3-7
Hi Moujiik,
> I have a file with some custom colors, and i want to make a template of it.
> But when i reopen the file, all custom colors are gone. Is this normal?
It's normal if you used File > "Export" to generate the file instead of File > "Save As".
File > Export is for writing just the selected objects to the given file, and also only styles used by the selected objects will be present in the file as well.
File > "Save As" on the other hand will save everything including all styles. So this is the one you want to use for making a template file.
Please let me know if that wasn't the problem.
...setting up a 3DM file that contains the styles you want to have...
http://moi3d.com/3.0/docs/moi_command_reference11.htm#scenebrowser
@Michael, it's not working. My custom colors are gone when i reopen the file.
@Benfarmer, what i am trying to save are the custom colors in style's edition panel.
Moujiik
Hi Moujiik, oh those custom colors - sorry I thought you meant your styles were not being saved.
I thought those would get saved automatically by Qt but I guess not. It looks like I should be able to save and load them to your moi.ini file so they will persist.
Thanks for reporting the problem.
Message deleted by Moujiik
Show messages: All
1-2
3-7
