Show messages: All
1-5
6-9
Hi Stefan,
> re:
> Warning: node /RootNode/obj1 uses unsupported transform inheritance type 'eInheritRrSs'.
> (Further warnings of this type squelched.)
> Wrote 261381 bytes of binary glTF to test.glb.
Is this when using MoI v3 or v4 for generating the fbx ?
V3 uses a pretty old version of the fbx library and V4 uses a recent one.
In v4 you can also edit moi.ini and change which version of the format will be used:
http://moi3d.com/forum/index.php?webtag=MOI&msg=8683.2
I'll also see about having an option in V4 for writing vertex colors. Oh yeah currently no colors at all are written to fbx, I'll also see if I can get materials going for that.
Hi Stefan!
Thank you very much for this news.
ASAP I will take a look to it just to see how could I use this new tool.
Thanks.
I am currently still using MoI v3.
Thanks for the info!
That would be nice, if you could add that in the future!
Best regards
Hi Marco,
FYI, it seems that Facebook has currently a file size limit of 3MB... so
you have to export as low poly model, since the compression parameter
is not yet accepted there... Exporting as NGons/Quads works fine!
For larger 3D models in Facebook i used in the past Sketchfab.
https://help.sketchfab.com/hc/en-us/articles/205642585-Facebook
Best regards
Show messages: All
1-5
6-9
