4-23
24-43
44-61
Thank you Marco, meanwhile I´ve got it.
When I want to draw a line, I need the shortcut 1.
The icons don´t function?
Hi Rudl.
I'm glad that you finally resolved :)
But what do you mean with "The icons don´t function?"
All icons in all panels and UI of my custom setting works without problem for what I know.
Could you post a video capture or a screenshot ?
Thanks.
I'm sorry Rudl if I ask you :) but...did you read my very first post of this thread ?
It's the main resource where all is explained.
If you want to know the main shortcut of my config, to open all the panels and UI you must read this PDF :
http://take.ms/tpN7P
There you can find all the info.
Ciao!
Marco (mkdm)
Thank you very much for your patience. I downloaded the PDF already but I didn´t read it.
Thank you much more for your excellent work.
You're welcome Rudl!
I'm glad that you like my config :)
If you still have some trouble don't hesitate to ask and ASAP I will help you.
Ciao!
Hello everyone!
Some minutes ago I've renewed the very first post of this thread, the place where you can always find ALL the things needed to get my personal config work.
I've corrected a little error in my shortcuts definition.
You can download the correct file at :
http://take.ms/Lxk5b
For any help read the point 5 of the very first post of this thread.
Ciao!
I know it is somehow off topic but given the opportunity will ask for it: those ‘fat lines’, ‘morph 2 curves’, ‘hatch it’, ‘put on the ground’ and ‘face edges’ plugins… where they can be found, so that someone can download them separately?
Thanks!
Hi Dimitri.
No problem.
@You : "...where they can be found, so that someone can download them separately?..."
Well...sincerely apart from Max'stuff and some few others I really don't remember who and when coded that things, and where you can find it.
Unless their creators have written something into to the code's comment.
If I remember well one of the user of this forum some times ago posted a repository where you can find many commands/scripts but I think that it is not so updated.
I don't know ;)
BUT, WITH THAT SAID, THIS IS NOT A PROBLEM AT ALL.
For what I know, I'm one of the users who has the most updated and complete repository of all most important plugins developed for Moi until now.
You can for sure download the stuff that you can find in the very first post of this thread (
http://moi3d.com/forum/index.php?webtag=MOI&msg=8848.2) and use only the stuff present in the "commands" and "scripts" folders.
Those files are updated to 1 week ago (26 feb 2018) and there you can find all the plugins you need, without the need to install my whole personal configuration of Moi :)
Have a nice day.
Hi Marco, I haven´t found the nodeeditor, so I tried to install the newest version on V4. Unzipped it and put it the UI folder. But,now in the optionswindow of V4 under shortcuts, i find all shortcuts from v3. Is there a way to seperate it.
Hello Rudl.
I'm sorry if I repeat again but :)
"Did you read the very first post of this tread ? ":) There you can find all the info you need :)
1) First : Read the title of this thread : "Marco (mkdm)'s very personal Moi V3 - A gift for all moiers :)"
This config works ONLY for V3. I said this into the first message of this post.
ASAP I will update it to work even with V4.
2) @You : "...i find all shortcuts from v3. Is there a way to seperate it...."
You have to ask Michael. I don't know how V3 and V4 manage their shortcuts, I'm sorry.
I have no problem because I use the same shortcuts on both versions.
3) @You : "... I haven´t found the nodeeditor,..."
Always from the first post of this thread :)
"I decided to not include into this package only the NodeEditor because each of us has for sure a very different version of N.E. :)"
Ciao!
Marco (mkdm)
Ok Marco, thanks! : - )
Hi Marco & Rudl,
For the Windows version v4 uses the same shortcuts as V3, from the same entry in the same moi.ini file so that's normal that they will be the same.
For the Mac version v4 uses a separate area of the moi.ini file ([Shortcut Keys Mac] instead of [Shortcut Keys]) than Mac v3 to avoid conflicts with Mac v3 which did not support using Alt+ separately from Cmd+ . It will be initialized though with the contents of the v3 [Shortcut Keys] section.
But any new shortcut keys you create in Mac v4 will be separate from Mac v3 and stored in the separate section in moi.ini .
Why the same shortcuts, when the don´t function in V4. V4 should have it´s own shortcuts.
Hi Rudl, what shortcuts do you have that don't function in V4 ?
Hello Michael.
@You : "...For the Windows version v4 uses the same shortcuts as V3, from the same entry in the same moi.ini file so that's normal that they will be the same..."
Thanks for the info :)
About Mac side, because I have Windows 10 Pro and I don't know if my personal config of V3 can work well also on Mac Os,
I think it's better that I put more emphasis on the first post of this thread that this config is tested and works well only on Windows machines.
I've already did so when I published the post for the very first time, but maybe it's better to write this annotation with a bigger character :)
A couple of minutes and I'm going to update.
Ciao!
Hello everyone!
After helping some of you during the config of my special version of Moi V3 I realized that I had to renew the instructions and manual :)
So, some minutes ago I renewed the very first post of this thread (
Please, read always the very first post in order to get all the info you need to setup this special version of Moi V3.
I will always keep up to date that post when I change something.
Ciao!
Hi Marco,
I just came by MoI3D's forum this morning and - by inspiration - clicked on this forum thread describing your customized MoI setup ... I decided to watch your short introductory video (intentionally without sound I assume?) and would like to say that it looks awesome what you have done ;-) ... A major expansion of MoI3D's IMHO already fine UI ... Many thanks for sharing! ...
Cheers,
Jesper
Marco, once more.
Thank you very much for your gift and your patience for me.
Rudl
Hello EVALON.
@You : "...(intentionally without sound I assume?) ..."
Yes, intentionally. English in not my native language so I prefer to record without voice ;)
Thank you very much for your kind words. I'm glad that you like my setup.
ASAP I'm going to make a little update in order to make it work also with Moi V4 and not only on V3 as is actually.
Have a nice day.
Ciao!
Hello Rudl.
You're welcome! No problem. It's fine that now all works for you (I assume...)
Remember that for any update or help, you can always take a look at the
There you can always find all the things you need to use my setup.
If any of you notice some kind of mistake please let me know and ASAP I will update the first post.
Ciao!
4-23
24-43
44-61
