Full Version: Concept car design in MOI?
Show messages:  1-2  3-22  23-42  43-57
27 Feb 2018   [#23] In reply to [#14]
Hi Marco,
>> ...not really for everyone :) <<
I did not refer exactly to this software but wanted to share Pilous amazment how accessible in general
digital tools nowadays have become to even modest bugdets ...
"Amazing what "normal" public progs can do today!"
Message 8845.24 was deleted
27 Feb 2018   [#25] In reply to [#23]
Hi Tom.
To avoid going too off-topic here, I created this new thread :
http://moi3d.com/forum/index.php?webtag=MOI&msg=8849.1
Ciao!
Marco (mkdm)
27 Feb 2018   [#26]
Another possibility:
I wrote this car modeling tutorial in 2015 shortly after Max Smirnov published his SubD scripts for MoI. The car was modeled 100% in MoI.
http://moi3d.com/forum/index.php?webtag=MOI&msg=7389.1
27 Feb 2018   [#27] In reply to [#26]
Hi Ed!
Oh..yeah!
I remember very well your amazing tutorial about sub-d and car modelling in Moi!!
Amazing tutorial!
Personally if I have to go with subd-d, altough Moi+Max's SubDiv is a GREAT tool, I prefer to jump into a classic Poly/SDS modeler and do all the stuff there.
A true sub-d modeler can offer a greater flexibility and many more tools for that kind of operation.
Anyway your tutorial was a mind-blowing piece of "art"!
Thanks a lot.
27 Feb 2018   [#28]
Thanks Marco. Yes - Max's SubD tool is great, but as you say, not a substitute for a dedicated program (nor intended to be I'm sure).
What I like about it is that it's simple, and you stay within MoI. The biggest issue is the lack of ability to specify edges that you want to preserve sharpness. I think if more work was done in this area it would be extremely useful. There are situations where one needs an organic shape and the script is very easy to use.
And thanks again Marco for introducing me to Affinity Photo and Affinity Designer. Inexpensive, very easy to use programs that allowed me to simplify my workflow. I no longer use Photoshop and Adobe Illustrator in my business.
27 Feb 2018   [#29] In reply to [#28]
@You : "...And thanks again Marco for introducing me to Affinity Photo and Affinity Designer. Inexpensive, very easy to use programs that allowed me to simplify my workflow. I no longer use Photoshop and Adobe Illustrator in my business..."
You're welcome!
With Affinity Designer and Moi I'm experiencing very very powerful 2D workflows!!
At Affinity team, seems that times is ripe for new powerful functions in new releases. Maybe this summer.
I'm talking about some kind of deforming tools for curves and other advanced vector tools.
In this way Affinity Designer will become an even better companion for Moi.
Ciao!
28 Feb 2018   [#30]
Hello, for this thread I made a Tesla Base Model 3, it takes 2-3 hours:
-Draw the baselines.
-Make simple normal Networks.
Now my old ISO-lines-Recon-Polyline-Straight-Loft-Sub-D Methode:
Reconstruct Curves with polylines.
Straight-Loft.
get the Isocurves.
The advantage vs a normal Polytool, is you get easy a good meshflow with the Isolines.....:
Reconstruct Curves with polylines./Straight-Loft.
...and you can use the base-network-patches to surface-snaps the Poly-Vertices.
The next steps are this way:
Now the first result:
Nice, but the tesla 3 has some sharp lines, they are suddenly stops.
How you can stop the flow and sharp the lines:
Delete a poly-patches where the flow should stop and splite with the subd-split script.
and Repair simply with two lofts, the triangles are welcome in this case.
Now the result, with the first "Stop-Line"
Tadaaaa
the way there too
Result three
more sharping lines
Now the Final Results for the base shape
with baselines overlay
I think for only 3 houres work ist clean enough
now you can use the main power of MoI and Trim Cut the clearance, windows, lights, and all the things you Need.
28 Feb 2018   [#31] In reply to [#30]
Amazzzzziiiiiiiiinnnnnggggggg!!!
@You : "...it takes 2-3 hours: ..."
LOL :) LOL :)
For me it took two days :)
28 Feb 2018   [#32]
yes, the hardest work is to find the base lines for the right flow, this takes 1 hours, but I have meanwhile a good Feeling for this things.
The rest is assiduity work.
28 Feb 2018   [#33] In reply to [#32]
And where do you find "BluePrints" ? Have you some favorite sites ?
28 Feb 2018   [#34]
Google
https://www.google.de/search?q=tesla+model+3+blueprint&source=lnms&tbm=isch&sa=X&ved=0ahUKEwi4_re2s8nZAhUnsaQKHQU-ArIQ_AUICigB&biw=1680&bih=881#imgrc=CxwVLda9z1cG2M:&spf=1519848109229
28 Feb 2018   [#35] In reply to [#34]
Big choice indeed! :)
1 Mar 2018   [#36]
1 Mar 2018   [#37] In reply to [#30]
next steps
patch repair.
Trim: clearance, windows, lights
Tadaaa
the clearance has now no fillet, this only a test.
Render Test for the flow:
1
2
3
4
5
Fast try to rebuild the tesla commerial Image
1 Mar 2018   [#38] In reply to [#37]
Masterpiece!!!!
Thanks!
Just a question.....but....do you have a Tesla car ? :)
1 Mar 2018   [#39]
Wow cool this method with the subdivision surfaces fantastic and brilliant idea.
4 Mar 2018   [#40]
Zarkow,
Thanks for sharing!
4 Mar 2018   [#41]
Zarkow - Thank you for making the tutorial. The Tesla Model 3 came out very accurate.
4 Mar 2018   [#42] In reply to [#1]
Hi
You could use Rocket 3f . Moi 3d is a great programme but if you want to make cars you may find Rocket a bit easier.
BW
Keith
