Full Version: Concept car design in MOI?
Show messages:  0-19  20-39  40-57
24 Feb 2018   [#1]
I did a search and see that there are many threads on the subject. I get the impression that MOI might not have best tool set for this type of work? Some people showed cars they have done in MOI but frankly they looked not very professional.
This person on the other hand was the first I saw who's model looked more in the direction of a professional looking model- https://www.youtube.com/watch?v=2l7Uxwxzfik
Now the ultimate software for car design (non engineering designers) is AD Alias. I can't afford it. That leaves Rhino and MOI for me. I already use Maya software and have made enough cars in it but to have 100% control over surface and flow Nurbs is better.
So my question is, if MOI is not the best tool for concept car design, do you think Rhino has better tools for that kind of work? or is there daylight between Rhino and Alias too? I am not talking about class A surface etc, it just needs to look perfect for renders.
Note- By concept car I mean, I already know how the shape of the car will look as I have sketched and explored the form in Maya.
24 Feb 2018   [#2]
Have you seen that ? The complete engine free style of your car video! By the same author of course! ;)
http://moi3d.com/forum/index.php?webtag=MOI&msg=8797.1
24 Feb 2018   [#3] In reply to [#1]
Hi Curious,
MOI is much, much more potent as the first impression and the examples you mention suggest.
I come from polymodelling and, as you, needed a Nurbs tool to have "100% control over surface and flow"
Tempted by the very affordable price I decided to give MOI a try. It took some time to rewire my brain to get accustomed to the pretty different modelling approach of a nurbs modeller.
But the more I worked with MOI the more I got impressed and delighted by its absolutely brilliant architecture and worklflow and more than once while working the sentence "I love you Michael" (the mastermind behind MOI) escaped me when discovering one more of these little genious time saving functionalities which make it such a pleasure to work with this tool.
No other software allows me to manifest my ideas at such an effortless speed and in such a tidy enviroment as MOI.
If you want to model automobiles with hundreds of individual parts which need to be organized in groups you may miss a more elaborate object manager.
In your case I would just download the trial version and give it a try for a while. Maybe you will be the one who takes automobile design with MOI to a whole new level ! ;-)
24 Feb 2018   [#4] In reply to [#1]
Hi Curious - it kind of depends on the specifics of the individual design. But MoI is missing a few continuity related tools that are in Rhino, like Rhino's MatchSrf command. So if those are important for your particular design then Rhino could be a better fit.
Vehicles can kind of fall in a gray area between mechanical and organic shapes, and MoI is somewhat more focused on the mechanical side of things currently, mostly because organic shape design with NURBS is an advanced and difficult area of NURBS modeling and can be pretty finicky. It has a higher learning curve.
It can often be better to do very organic shapes using sub-d modeling rather than NURBS. NURBS modeling is very strong when much of your design can be defined by 2D profile curves and boolean operations, that's the area where MoI is more focused on currently.
24 Feb 2018   [#5]
Three other ways
https://onedrive.live.com/?authkey=%21AKmJ2yoRUchPtTE&id=1C86BCB357547A01%21239&cid=1C86BCB357547A01
25 Feb 2018   [#6] In reply to [#4]
>> MoI is missing a few continuity related tools that are in Rhino<<
Could you forward some specific details in which cases MOIs modelling toois are less capable
than Rhino´s ? Do you refer to a sort of enhanced blending modes or are there modelling
tools in Rhino which MOI is missing entirely ?
TOM
25 Feb 2018   [#7]
Cheap solution for really good surfaces you need virtual shape (VSR) for Rhino, unfortunately autodesk buyed it and now you must pay 10000€ a year instead of on time 1000 € for VSR and Rhino.
Now you must take Alias Designer, Solidworks or Catia....Rhino alone has the same surface problems despite the better tools.
25 Feb 2018   [#8]
by Won Park
25 Feb 2018   [#9] In reply to [#7]
>>I am not talking about class A surface etc, it just needs to look perfect for renders<<
It looks like Curious goal is not the ultimate software for hyperaccurat car modelling purpoeses but a Nurbs tool to build realistic render models. MOI may miss some very sophisticated surface blending functionalities but the brilliant worklflow and extremly fluid workflow, in my eyes. is a strong argument to at least give it an extensive test run.
25 Feb 2018   [#10] In reply to [#6]
Hi Tom, well like I wrote above probably MatchSrf is the biggest missing one. There are other techniques you can use though.
Building a patchwork of surfaces instead of using solids is a much more difficult and advanced type of NURBS use, which is why it isn't a big focus area for MoI currently. The place where NURBS really shines and is easy to use is for constructing objects from 2D profile curves and using booleans. MoI is currently more focused on that area where NURBS delivers the biggest benefits in comparison to sub-d modeling.
Modeling organic forms that are not easily expressed just by 2D profile curves tends to be an area that works better in sub-d modeling.
26 Feb 2018   [#11] In reply to [#10]
Thank you for the info, Michael.
26 Feb 2018   [#12]
Amazing what "normal" public progs can do today!
(here 3ds Max + Lumion 8) Look it in Full screen !
26 Feb 2018   [#13] In reply to [#12]
"Amazing what "normal" public progs can do today!"
And they are available for everyone ! I see problems at all to model cars like
in the video in MOI - on the contrary I doubt if there is another software which
could do at such a speed - surely no polymodeller ...
26 Feb 2018   [#14] In reply to [#13]
Hello Tom!
@You : "...And they are available for everyone..."
From Lumion's official web site :
Lumion € 1499
Lumion PRO € 2999
...not really for everyone :)
26 Feb 2018   [#15]
Yes fortunate people...but you can use some free Blender, Unity, Unreal... progs (maybe not so easy) :)
Here Blender!
119$ but you can make your own...
your free own :)
27 Feb 2018   [#16]
Four of my modelling ideas, too:
http://moi3d.com/forum/index.php?webtag=MOI&msg=8548.3
http://moi3d.com/forum/index.php?webtag=MOI&msg=8696.1
http://moi3d.com/forum/index.php?webtag=MOI&msg=8470.7
http://moi3d.com/forum/index.php?webtag=MOI&msg=8845.5
27 Feb 2018   [#17] In reply to [#16]
Thanks a lot Zarkow for reminder!
Amazing tutorials with very powerful techniques.
I've learned a lot studying your tutorials!
Could you please create a repository or a specific forum thread where we can find ALL he most important lessons or tutorials created by you ?
Maybe you could divide that repository (or thread) into main category....something like this for example, and update it from time to time...
1) Car modelling techniques
- url 1
- url 2
2) Organic modelling techniques
- url 1
- url 2
3) Hard edge techniques
- url 1
- url 2
This could be a huge help for every newcomer and also for all other Moi's users.
Do you think is it feasible ?
Thanks anyway.
27 Feb 2018   [#18] In reply to [#16]
I added a link in the wiki to the above message (http://moi3d.com/forum/messages.php?webtag=MOI&msg=8845.16).
27 Feb 2018   [#19] In reply to [#18]
Wanderful!
Thanks a lot Michael.
27 Feb 2018   [#20]
A cool vade-mecum!
