Show messages: All
1-3
4-9
More tricky second level than my basic try! :)
Thank you both Pilou and Michael !
Hi Michael, is it possible to extend this command? I would like to use one shortcut instead of two. For example, If I click a hotkey it will trigger the bounding box center, the next click will make it a normal move/scale/ command. So you can choose between these commands while using only one shortcut.
Hi surferdude,
Yes, in v4 it's possible to set up a shortcut key that will do that. Here is what you would put for the command part of the shortcut keys:
script: /* Scale, switch between center and regular */ var didcenter = false; try { didcenter = moi.command.getOption( 'scale_center' ); } catch(e){} if ( didcenter ) { moi.command.execCommand( 'Scale' ); } else { moi.command.execCommand( 'Scale BoundingBoxCenter' ); } moi.command.setOption( 'scale_center', !didcenter );
script: /* Move, switch between center and regular */ var didcenter = false; try { didcenter = moi.command.getOption( 'move_center' ); } catch(e){} if ( didcenter ) { moi.command.execCommand( 'Move' ); } else { moi.command.execCommand( 'Move BoundingBoxCenter' ); } moi.command.setOption( 'move_center', !didcenter );
Amazing!
Thank you a lot! It will make my work way easier!
Patiently waiting for the final release of v4!
Nice!
Show messages: All
1-3
4-9
