Show messages: All
1-3
4-9
PERFEKT!
Does exactly what i need!
Thanks a lot!
Can i use the code for my "STLimport&clean" script i'm working on?
You can use everything !
I think that here the unique true "owner" of any code is Michael :) ...the "hidden hand" behind all our scripts and plugins :)
Ciao!
42 Karma points to you and all our Gurus (incl. Max)
Hi Ralf,
> Let's say i have a 10 sided polygon and i like to get a curve through all the points.
You can also use the existing Rebuild command for this task, there's an "Endpoints" mode that will build the new curve by interpolating through the endpoints of segments. There's also a "Break angle" parameter where it will keep sharp corners at lines greater than the specified angle, if you want no sharp corners preserved at all put in a high angle like 180 for that value.
Hi Michael.
Thanks a lot for the reminder :)
Wow this is even better..
Never used Rebuild before....
Thank you Michael to let some more light into the endless box... :-)
Show messages: All
1-3
4-9
