3-22
23-25
Arghhh, man you are Genious, I feel like total idiot now, i tried with center line and all kind of stuff and it always went a bit wonky and wobbly in middle and around joints when i used network or even lofting with 2 smaller circles etc. etc... I never thought of creating network on these 4 curves :(.
Thanks a million
Ok Now when i tried myself (it's easy ;)) i think i've jumped to the conclusion too early. Although it looks same on first view when tumbling in 3D it's definitely not same. Network version is different and less dipping surface. Check the Quad view and compare it, it is not correct sadly.
Hi Lewis, if you want to keep 100% exactly the same shape you can untrim it and then retrim it. To untrim you need to use Edit > Separate on it first so it's individual surfaces, then select all edges (either select one edge on each surface and use Ctrl+A to select all edges or use the Scene Browser > Types > Edges click the selection dot area on the right) and hit Delete.
And before doing that select all the edges you'll need for retrimming, use Ctrl+Drag or Ctrl+C/Ctrl+V to duplicate them and then squish them flat in a side view using "Flat snap" (
http://moi3d.com/forum/index.php?webtag=MOI&msg=3378.4), then you'll use those as the cutting objects in Trim.
If you want to construct a new shape, Sweep is good for building a potato chip like curved shape from 2 crossing curves, you can select one as the profile and one as the rail even with the profile in the middle of the rail. That will build a 4 cornered sheet, then Trim with a circle or oval shape 2D curve.
I've tried with re-trimming but as soon as i delete edges on that power button shape i get complete mess of surfaces so even after flatten/re-trim it's nothing usable.
This happens when I delete edges.
As for Sweping, i tried that also but i get visible Seam in middle of one line when i try to export that to polygons (2nd attachment).
Hi Lewis3D.
..I see...
But I've got a trick that worked for me.
Some minutes and I will post a new tutorial.
Stay tuned.
Check this one.
Video tut :
http://take.ms/pgaSX
3DM file :
http://take.ms/mlW8T
Ciao!
Maybe Just redraw the 2 perpendicular curves by the Known points
Sweep
Trim :)
Hi Lewis,
Yes, those are just the 5 surfaces that were underneath the faces. Why are they unusable for you? If it's confusing that they are overlapping, then try untrimming and retrimming just one at a time and hide the other ones while you work on each individual one.
It looks like one of the curves you are using for the sweep is not smooth. If either the rail or the profile curve isn't smooth then the sweep will also not be smooth. A quick way to smooth out a curve made of 2 pieces is to turn on control points and delete the middle point. Or also select the center point and the 2 adjacent points and make sure they are all in a straight line, using either flat snap or Transform > Align.
If you still have any problems with the sweep please post the 3DM model file with the curves you're using.
Hi PILOU,
Thanks for trying.
I've tried that several times and i always get visible seams or even holes after i try to export that to polys. Not even join or Boolean union helped to solve that.
Have you tried to check your version for OBJ exporting ?
Guys thanks for all the help, amazing forum :).
Marco, i managed to do it with that new technique you showed and it's clean one export. I guess Curve Rebuild was key part here so that after sweeping tool all is seamless now.
Great, thanks one more time.
Hi Lewis, I've attached the result of using the untrim/retrim technique as I described above. The surfaces that you get after untrimming are perfectly usable, they just extend over top of each other so it's easier to manage them by only untrimming and retrimming one at a time, that's all.
This version should have the 100% exact same surface shape as your original file since it actually uses the same surfaces.
If you want help with making a new surface using Sweep please post the curves you are using, it looks like they need to be edited to be smooth instead of having a kink in the middle of the curve.
lewis_untrimmed.3dm
Message 8827.14 was deleted
Hi Lewis3D.
You're welcome.
Ciao!
Thanks Michael, yes your file works fine, as for me not managed to do it by trimming, it is exactly what you say, many surfaces overlap each other so i hardly see/understand which part i'm trimming in that mess, i've tried by hiding all but one and then trim one by one by one but i can't say i got great result 'coz even after i trimmed all with outside circle and deleted outside excess areas i still have many overlapping surfaces with corners bending upwards so i've not known how to weld/merge them into that single flat nice surface you got (my screen-grab showing how surfaces are bending upwards=.
Luckily Marcos's solution worked so i managed to fix it with that technique.
Hi Lewis,
Those bending upwards areas are some additional areas that also need to be trimmed off - if you check out the file I posted I also drew in 2 crossing lines here:
Then you trim the surface and remove these areas:
Leaving this part:
<< and i always get visible seams or even holes after i try to export that to polys. Not even join or Boolean union helped to solve that.
<< Have you tried to check your version for OBJ exporting ?
Yes and Seems not seams! :)
I made a little thickness because render don't love only simple face! :)
Always free real time SimLab Composer Lite (max 1920 * 1080)
Aha, i get it now how you did it Michael, you basically made 4 pizza slices and then it worked 'coz bending parts are removed. I forgot tot do that cross section trim so that's why i still had messy results.
PILOU - thanks for render test
cheers and thank you both for extra effort.
Beatiful!
Tks.
Hi Lewis,
>>I've tried recreating that surface with network
Attachment with layout for NetworkSrf (This eliminates polar uv layout)
power_removeX.3dm
Interesting approach EDDI, does it look same from side in quad view ?
And how did you split edges/curves at exact position, by trimming or there is faster way to split curve/edge ?
3-22
23-25
