Full Version: how to set up the object library
Show messages:  1-20  21-23
27 Feb 2021   [#21] In reply to [#10]
Hi MOI users, I am having the same problem where the object folder won't let me add anything to it. I had a bit of a struggle just getting the Custom UI to work. So I am trying to figure out what I did wrong. In reading this post on. How to set up the object library. Sure sounds like I un-zipped the file one layer to deep. Wonder if anyone could explain what I should do. I read this post over and over. But just wanted to see if anyone could steer me in the right direction. Thank you for any tips.
27 Feb 2021   [#22] In reply to [#21]
Hi Specktech, can you show a screenshot of the directory structure that you've set up?
Also what operating system are you running on?
27 Feb 2021   [#23] In reply to [#21]
Try running MoI as Admin.
